1 - 18 of 18 Posts
uva uvam vivendo variafit
I have a run of the mill Toro (MTD) lawn tractor. The battery wouldn't turn the engine over last night, so I put a charger on it until it was full. Without running it today, the battery is again dead. If I buy a new one, this will be 3 batteries in 4 years. It seems that the only batteries available for lawn tractors are cheap $50 products. Are there better ones out there, do they just die like this, or is there something odd at work?
Framing Contractor
My last tractor made it 15 years on 2 batteries. Are you sure your charger is working properly or is on the correct setting? If that checks out, I would buy a different brand of battery at least.
A Little Of Everything
For the most part, your off-the-shelf lawn tractor (and motorcycle) batteries are pretty crappy. Consider yourself VERY lucky if you get 2 years out of one.
But not all of them.
When my sons & I were doing our side-line lawn care business, we a John Deere F525, with a John Deere battery in it. The battery lasted (I believe) 6 years. I'm not sure if we were just really lucky, or what.
Pretending to be Retired
Do you have a multi-meter where you can check the current draw from the battery when the switch is turned to the off position?http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
If you have a current draw then you need to fix it first before you replace the battery.
Or do you have a hydrometer and is the battery the type where you can check the 6 cells for charge? If you can check the individual cells for charge, and one or more are shot then the battery needs replacing. http://www.ehow.com/how_4964575_use-battery-hydrometer.html
Either the battery is shot or there is a current draining the batteries.
I pretty much agree with DrHicks on this one, but three batteries in four years is a lot, under any circumstances. So, again, agreeing with DrHicks, I have always bought lawn and garden batteries from an implement dealer or auto parts store, and have not based my puchase decision on price, but on their recommendation for my application, and I have had good results doing so. I have heard others tell of "getting a deal at XXX" (local big box or whatever), but I have also heard the same ones tell the same thing in consecutive years, so, in my opinion, they are not saving a thing. The other thing that you need to look at, particularly on "price competitive" equipment, is the wire size, types of terminals they use, etc. I would suggest that while you have the battery out, look at the ignition switch, light switch, safety interlocks, cable connections, etc. Take the wires loose, examine them, clean the connections, and reinstall them. While they are not necessarily carrying full voltage to the starter, a little bit of excess voltage draw here and some more there can add up to enough to cause the charging system to struggle keeping up, and while it may be enough to appear that everything running fine, over the long haul, or short haul in this case, can mean that your battery is not adequately maintained.
Hey here's a kicker for ya...
I've got a Kawasaki Vulcan motorcycle. Bought it new in April of 2005. This will be my 7th season of riding it on the original battery. No idea how I've managed to pull that off, but this guy ain't complaining!
Discussion Starter #8
Thanks for the input all. I'll look into it when I get back in a couple days. I do have a multimeter and it's a piece of crap, but it might just be able to root out a current drain. Mike - I use a smart charger currently and it does a pretty good job (I assume that is what you meant by your post as opposed to your specific charger).
Our battery was constantly being drained, even after we recharged it. We changed it 3 times, finally we found out it was a faulty Stator.
Good luck.
Current drains are sometimes very hard to find. I just traded my loved 1999 Chrysler Town and Country in because of that very problem. It had a small current being used that would over 4 days draw the battery down so it wouldn't start. I knew it was in the fuel system somewhere (when I removed that fuse the current draw stopped), but nothing I did would fix the problem.
So if the tractor doesn't have any phantom current draws, and all battery connections are good, and starter relay is good, maybe you have just gotten bad batteries. Speaking of starter relays, have you attempted to jump the tractor bypassing the starter relay? It could be bad especially if it has some age on it.
Good Luck and be safe
Something is draining the battery. Lights, ignition switch, hour meter...something. My John Deere did the same thing. Take it to a dealer to have it fixed for sure.
hi, one fellow here in savanna, illinois took a ride to o reillys in freeport,illinois and picked up a tractor battery with the most cold cranking amps and still fit the battery tray under the seat. $45.00 , and has used it 3 years now, no trouble.
Jack of all - master none
I just bought a replacement for my tractor from Autozone, which came with a 3-year free replacement warranty. With the $10 core credit from giving them my old battery, the total cost was like $30.
Discussion Starter #15
Well, it's drawing a 5 amp current when off. I guess I'll just take it to the shop, but I'll probably wait until it needs some other maintenance (hopefully not until fall).
So you have a large, presumably red, cable running from the positive terminal of the batter to the starter solenoid, and from one of those points you have a smaller, again, presumably red, wire running from either the battery or the same lug on the starter that the cable is connected to, to the ignition system. I would disconnect the wire to the ignition system, and check the current draw again. If it is still drawing current, I would suspect the insulation on the positive battery cable or the solenoid, but if the current draw is eliminated, I would suspect something on the ignition or accessory side, starting with the ignition switch.
1 - 18 of 18 Posts
