Are there any issues with installing larger ceramic tile on drywall, as a backsplash/wall feature around a bar area? I'm looking at 12 x 16 tile, installed with staggered joints.
something like this: http://www.homedepot.ca/webapp/wcs/...Ntx=mode+matchall&recN=0&N=0&Ntk=P_PartNumber
The area would basically be one 4 x 8 sheet of drywall vertical, then a 16" high x 6ft long backsplash above the counter top/sink area. My present wall is 2 x 4 at 16" o.c., it would be easy to double them up, and go 8" o.c., or should i remove this sheet and install a 4x8 1/2 ply or osb for better results? This would be more trouble, and would like to avoid it if possible... I would like to use a 1/8" grout joint, as minimal as possible. Would this be ideal for a wall application? Or should it be larger? The goal is to have a solid, lasting bar area that's different, unique, where there will be no cracks appearing...
Thanks for your input...
