I have a cape and I'm reinsulating one of the upstairs bedrooms. I used 2" XPS to create air baffles and used 3/4" XPS strips over the roof rafters to reduce thermal bridging. I'm filling the remaining space with R15 Roxul then covering with Certainteed Membrain as a vapor barrier and lastly airtight drywall. My issue is I'm going to have a large gap, about 1.75 inches, in the knee wall where the roof rafters meet the top plate. I highlighted the gap with a red box. What's the best way to deal with this so I can have airtight drywall? It doesn't have to look pretty since it's in the knee wall portion. The two options I thought of are cutting strips of wood to furr out the top plate. My fear with this is splitting the wood when I screw it in. The other idea was cutting more XPS foam to fill the space. The problem with that is I'll have to cover it with drywall for a thermal barrier (a big pain since I'll be screwing it in from below... talk about awkward position!).
Does anyone have suggestions?
Pre drill the furring strips to avoid splitting.
Discussion Starter #4
That's exactly what I did. I also put Lexel caulk on the back to help prevent small gaps when the wood expands/contracts. That, combined with a bead of Great Stuff Pro on the top, should keep the furring strips air tight.
Thanks for your help guys!
