1 - 7 of 7 Posts
I would like to connect this lighting fixture to a plug.
I have a plug switch and wire setup (SPT-1 wire and polarized plug 18AWG). Is it possible to connect it to the lighting fixture, and if so is there a way around the black and white wire need to be?
Thank you in advance for your help.
You can do as you ask, the question is what are you trying to accomplish? That fixture is meant to be mounted in a weatherproof box with connections to power inside the box. It is not intended to be connected to (in essence) a lamp cord.
Safety first.
Safety first indeed, which is why I am seeking advice.
I have this fixture spare and some lamp cord and I would like to make a lamp from concrete so would cast this part into it. Would you suggest it is not a good idea to do this? I would of course insulate the connections.
Semi-Pro Electro-Geek
That definitely should not be cast directly into concrete. There's no way to safely make the connections if you do that. Why not cast a proper electrical box into the concrete, and mount the fixture on it like normal?
Usually Confused
All electrical connections need to be in an accessible approved box. I suppose you could connect new one-piece lamp cord directly to the fixture connections then connect the male threaded fitting directly to a corresponding threaded fixture on the end of some conduit (to be encased in concrete), but that would negate any UL certification for the fixture and I don't know the rules for making a weather-tight conduit connection. Others no doubt do. Assuming your project is intended to be used outside.
Perhaps using a low-voltage lamp would make the project easier but I'll have to leave it to others to outline the rules for them.
To your original question, the wider blade of a polarized plug connects to the white (neutral) conductor.
Discussion Starter · #6 ·
Thank you mpoulton and lenaitch, I appreciate your input and I will seek a safer and more reliable way to complete the project. Good to get the feedback.
1 - 7 of 7 Posts
