have decided to install laminate floor on a concrete floor family room below ground.
family room now has a piano , though not a grand piano, is quite heavy. do you see any problems with a piano laying on top of a laminate flooring, seeing as it's press wood?
i plan on placing some type of protection below each wheel.
* in installing laminate flooring, is it a good idea to buy the laminates which already have foam attached??
* must all laminates be glued together?
thanks.
thanks.
