1 - 6 of 6 Posts
I have found Mirror lake laminate by Carpet One that the saleswoman said would work great in a bathroom. I have always heard that laminate was not for bathrooms. Is this laminate better quality, or should I steer clear from it?
I just installed Pergo in the family room and told my kids no drinks allowed....no questions asked. I told them this floor was no good near water because of it's composition.Then to prove my point I took a scrap of the Pergo and threw it in a jug of water overnight.... and nothing happened:eek:.
That said, I would only install laminate in a wet area if the manufacturer's warranty said it was OK for a bathroom... Mine had the underpad attached... not sure if that changed the water resistance Underlay could be an issue.
There is also a lot greater chance of water damage and residual water in a bathroom and I have read several threads here about water damage in foyers and sun rooms. Bamboo might be an alternative.:thumbsup:
· surfing and sanding
Laminate floor in the bathroom
You can install laminate floor in the bathroom. Make sure to use water proof sealent all around the walls , and around the toilet.
If you have kids and they splash water a lot this should help.
If the water stairs on top of the laminate floor that is ok , if the water will get under the floor this might lift the floor up.
hardwood floor hawaii
· Pro Flooring Installer
Install laminate in bathrooms at your own risk. Excessive water will damage it. Even the Swiffer wet jet voids the warranty on some laminates. Just remember if you have a problem with it , it probably won't be covered under warranty.
This really is the best answer.
It's fine if you make it fine.
If you have longstanding water often, then shy away from it.
I would not install any laminate in a bathroom regardless of what any salesperson or Mfg stated
--Especially a salesperson
We are not talking about a car salesman here....
1 - 6 of 6 Posts
