1 - 7 of 7 Posts
I am laying a pergo type flooring in about a 25 by 15 foot room, in smaller rooms ive never had a problem but with the longer rooms ive seen the boards start to seperate a little bit. I wanted to know it anyone has used and can recommend a glue I can use to help the pieces stay together a little better over time
I use a dab of the glue that's made for laminite floors, but only on the short butt joints.
Most often reasons laminite floors come apart are there not locked in all the way, when laying the pieces in place do not just insert them and try and lay them down all in one motion. Instead work them up and down getting closer to the subfloor each time to work it into the joint.
Someone nails the flooring to the subfloor or hits it when installing the 1/4 round, It can not be attached in any way to the subflooring.
Not enough gap left around the outside edges or around the doorways.
Most laminate flooring does not require glue, and I don't think it would be a good idea to use it on the joints as it would probably be a huge mess of glue to clean up. Maybe consider engineered flooring. It floats just like laminate, yet it looks better, most can be refinished in the future and best of all unlike laminate it is real wood.
It's water based glue and just wipes right off with a damp rag.
1 - 7 of 7 Posts
