Laminate Flooring
1101 Views 13 Replies 3 Participants Last post by  joecaption
I saw a small drop of water in one of the seams of my laminate flooring. Approximately a week later, several seams started to lift up. I tried to heat up the room in hopes to evaporate the water, but it hasn't worked out yet. Looking for some ideas.
1 - 14 of 14 Posts
What room is this?
Is it a slab or below grade?
If it's a slab is there heat or plumbing run through the slab?
joecaption said:
What room is this?
Basement floor. Basement never leaked. Just finished construction over summer. Had several parties and get togethers and then just recently noticed water coming up.
It is also below grade and there isn't any piping below concrete.
Most laminite not even beow grade rated.
Did you follow all the instrution on all the extra steps needed to install it below grade?
I believe so. My father-in-law has been doing construction for the last 30yrs. He was in charge, but now it is what it is. The biggest problem I'm having is I can't tell is something spilled or if is leaking in, because there is a small space between wood and plastic barrier every time you walk around the water keeps spreading. Don't know how to dry everything without pulling up the floor.
dehumidifier
joecaption said:
dehumidifier
I have one set up for about 2 wks. You think I need to just wait and give it time?
If your thinking the floors going to flaten back down, most likly that's not going to happen.
Once laminite gets wet it's shot.
Also by now there may be mold growing under it.
Sounds like the moisture is coming thru the concrete, if so, it will only get worse with time.
Sounds like a perimeter drain system and sump pump may be called for.
http://www.usinspect.com/resources-...stems-home/basements/interior-perimeter-drain
joecaption said:
Ok thank you. I guess I'll just have to pull up floor and clean up.
Thank you for all the advise. I just wanted to let you know I ripped open the sheet rock where it was the wettest and found a pipe with a small leak, which is where the water was coming from.
Thanks for taking the time to post again!
1 - 14 of 14 Posts
