Hey all,
Wife and I are currently in the middle of a flooring project at home. I've laid a few laminate floors before with success, but we've run into an issue here that I need some advice on.
We're replacing our entry, hall, living room, and kitchen with a laminate floor product. Entry, hall, and living room are no problem, it's just been carpet/padding over plywood subfloor.
As we approached the kitchen, we realized (after inspection) that the builders (home is 2 years old now) put down an additional particle board subfloor underneath the vinyl that is in the kitchen. So the kitchen has the plywood floor, particleboard, then vinyl.
This was all laid before cabinets, meaning the cabinets sit on the additional subfloor layer.
So here are my questions:
1. What is the right way to do this project (even if it's more work to do it right)? Remove the lower cabinets, remove the particleboard, lay the new laminate flooring, and reinstall cabinets? Or try and cut the particleboard out around the cabinets in place, and then lay the new floor.
2. If it's the latter, what should I use to get close enough to the cabinets to cut out the particleboard, keeping in mind the cabinets have a recessed toe-kick area that might make it hard for big tools to get into.
I appreciate your time and attention on this one :glasses:. Cheers all!
