Laminate hardwood floor pad.
It is the same not better .
The quality of the pad is what matters, you can get the laminate floor that has thin cheap pad attached to the floor so of course it will not be better then nice say 3 mm cork underlament (pad)
It is easer to install the laminate floor it the pad is on the floor.
Make sure to use the plastic moisture barrier if you install over concrete or if there is a lot of moisture in the subfloor.
