I am going to install laminate flooring in my new house and have a few questions regarding installation.
My questions are:
My questions are:
- Can I install over existing tile?
- Do I still need to install a moisture barrier, or will the tile serve as the moisture barrier?
- Top of tile is 1/8" higher than the concrete sub-floor. Can I install 1/8" plywood over the concrete sub-floor, thereby making it level with the tile, and than install the laminate over that?
- Will this plywood subfloor act as a moisture barrier, or do I still need to install a moisture barrier?
