1 - 2 of 2 Posts
I am in the process of purchasing and installing laminate flooring in my new house, and I have several questions:
1. How much should I pay for 500 sq ft. instillation
2. What type of insulation should I use on a bottom floor? we are laying down on top of existing laminate.
Thanks for your help!
Hey Lishlish,
I am not sure if I understand the second question. Are you laying new laminate flooring over existing laminate flooring? If that is what you are doing I would recommend that you don't. You should remove the old laminate before you install the new laminate.
Laminate is a floating floor and should be pretty easy to take apart and remove.
Cost for laminate flooring varies anywhere from $1 to $5 dollars a square foot.
Underneath the laminate flooring you usually use a foam underlayment. Hope this helps. -Gregg HD online community
1 - 2 of 2 Posts
