Hey guys,
I am helping my uncle rewire parts of his house. Most of the knob and tube has been replaced years before he moved in. The k&t that is left is in the basement and some main floor.
Here is my issue/question: (see drawing attached)
There are two lights on the main floor that are wired with k&t. There is a hot conductor that comes up from the basement and feeds two separate switches. At each switch, two hots go to feed the light. The lights then share a neutral back down to the basement. Each light is currently on a dimmer.
I am wanting to feed each light from different breakers in order to balance the rest of the loads in the basement.
Is it possible to feed the switch with Romex, then re-identify one of the hots going to the light as a neutral? I understand there will not be a ground wire fed to the light.
I have a concern about possible induction from using the k&t wires in such as manner.
Do I bite the bullet and do it properly and rewire the feed to the light?
My other concern is that if I keep the wiring the way it is I will have to add some junction boxes in the basement with a single hot joint and single neutral joint. I don't know if that is to code.
Thoughts?
Current wiring on the left of pic
Thoughts?
