1 - 6 of 6 Posts
Worked fine til I shut it off due to a city wide boil order. Turned back on and tripped GFI. Repair guy replaced recirculating pump. Still tripped. GFI replaced still tripped. Now repair guy says I need to change the 20A breaker because it must have messed up the entire electrical circuit. Is that even possible? Any ideas on what the issue could be?
Breakers do NOT mess up wiring !
The repair guy is speaking non- sense.
I would suggest you get a proper
Experienced and knowledgable electrician
To look at it instead !
It could be -
1 - wrong type/ size breaker.
2 - problems with building wiring
causing problems with the gfci.
3 - Electrical leakage in the appliance.
Most of these problems are best tackled
by an electrician.
1 - 6 of 6 Posts
