kitchenaid ice not making ice #ksrg22fkwh04
3741 Views 2 Replies 2 Participants Last post by  stevefastv6
check fill tube is not frozen first! if not unplug the unit from the wall. power to refrig. remove ice maker from freezer 3 screw 2 on door 1 for the ice maker will slide out .unplug ice maker from inside of freezer .remove square cover from side of ice maker. if possible remove module assembly pn#628399 from the side of ice maker 3 bronze colored screws . test fuse in wiring harness w/ volt/ohm meter .fuse is attached to mold heater assembly pn#2212351 . should be 0.00 resistance . diagram @ kitchenaid.com look for burnt contacts from motor failure! replace module assemby about 90.00 dollars local appliance repair center. after you install new part plug refrig into wall . keep a close eye and ear on ice maker for about three hours hope this helps fastv6
we have a Kitchen Aid side by side fridge.
Model # is KSRS2SCS**O*
The problem we have is the ice will not dispense. The store where we bought the fridge said we were not using the ice maker enough, thus the ice was getting blocked up. That was not true. We can't us it as it won't let the ice out.
They said they were going to replace the door, that was 6 months ago, and now 6 months after the warrantly has expired and they now refuse to do anything.
Is there anyone else out there having the same problem with the ice not dispensing.
reply
if you searched the internet this a common problem with kitchen aid brand! follow my instructions in my post? is the ice maker in the top of freezzer or is it in the the door? i bet it is the timer module either way check local appliance part department !!!!!!! before buying kitchen aide if you have feel free to ask:thumbsup:
