I've recently redone my kitchen with the newer deep sinks and a disposal on one side. The drain is at the same level but now with the lower sink the drain into the wall is just 2 inches or so below the disposal discharge. Will that work?
The drain runs horizontally for 5 or 6 feet in the wall, behind the cabinets before it drops down into the basement. Because of that it would be cost prohibitive to drop the drain line. Other options would be to get a more shallow sink, which again would be expensive and not appealing for other reasons. So, the only viable option if the 2 inches isn't enough will be to do without a disposal, picking up 3 or 4 inches in the process. Can I get by with the drain being only 2 inches lower than the disposal (with a p trap in between)?
