1 - 8 of 8 Posts
In redoing kitchen I noticed my current kitchen drain is not in center of sink cabinet. It looks to be about 6 inches off from center. Can i still install the drain without an issue? I may have to run the pipe lateral a few inches. Can this be done without an issue?
Got a picture?
As long as it runs down hill it should be fine.
Retired Moderator
Yep--as long as the drain is inside the base cabinet you will be able to make that work---
I had same issue when going from an old double bowl sink to a new single bowl. remedt was to use a 1.5" 45 fitting on the stub out from the wall then a short piece of 1.5 then the trap adaptor
1 - 8 of 8 Posts
