Hi all! I am replacing the drain assembly under the kitchen sink. I mocked up an ABS assembly and I have a question about the p-trap. I figured it would be best to use a p-trap with a union... I also bought one with a clean-out plug, but the union seems like a better option - should anything fall into the drain, a clog, etc. I also figure that a union would allow easier incorporation of a garbage disposal... should I ever decide to install one. The old ABS assembly had a p-trap w/ union.
Haven't glued it up yet. Does everything look okay? Am I correct in my logic in wanting to use the p-trap with the union?
Thank you!
Thank you!
