Hi everyone,
I’m new to this website but I’m glad I found and hopefully someone can shed light on me to figure out my problem. So here is my problem: my kitchen ceiling lights and my outdoor lights to my backyard stopped working. I have 2 GFCI outlets in my kitchen and they work fine, tested and reset them. I have a GFCI outlet right below my outside back lights and that doesn’t work. I switched a working GFCI outlet from inside to the outside GFCI outlet and it still doesn’t work. I went to my main panel of breakers, switched all to the OFF position and turned them back ON with no trip to any of them. All the breakers have power going to them. It seems like my outside backyard GFCI outlet, the wiring has no power flowing cause I tested with a voltage tester, as well as my kitchen light switch and an outlet right below it cause no power flowing. Everything else in the home works perfectly fine just those two areas of the home. Any help would be appreciated!
Luis
Luis
