Getting new cabinets and an island installed in the kitchen. I have to run electrical through the concrete slab to the island. Going to rent a concrete saw and cut the trench myself. I already verified that I do not have a post tensioned slab (a stud finder on the "metal stud" setting works great for finding the rebar grid, by the way).
The island will have two outlets (mounted on the sides away from the counter overhang) and be GFCI of course. I plan to tie them in at a wall outlet box 6 feet away. I've been running web searches for the last month and so far I've gathered that you can't run Romex in conduit, that I should use PVC, and that I should use wire made for use in wet environments.
What I'm not clear on is what size conduit to use and since I'm not familiar with PVC conduit at all I'm not completely sure how to make a 90 degree turn to come up out of the trench. Does PVC conduit have fittings just like PVC sprinkler pipe? I feel like an idiot asking a question like that, but I've only had experience adding outlets and working with Romex to wire ceiling fans and the like... this is my first time dealing with conduit.
Also I'm unclear about transitioning from the PVC to the first outlet. Can I go straight from the PVC into flexible conduit?
Thankfully I convinced the little woman that running gas for a stove or a drain for a sink was beyond my abilities for the island.
