Hello,
I want to know if I have a problem here or not. The situation is that our kitchen installers came and installed the kitchen this weekend. It turns out that one of the cases was 1/4" out of square. This is a corner cabinet, so you don't visually see it. But it meant they removed a portion of the drywall behind the cabinet to make it fit properly with everything else.
So, behind the cabinet now, there is about 3 feet x counter height section where we only have the vapor barrier (which was taped well with tuck tape, so there is no airflow across the barrier).
Is this a long term problem? will I run into moisture problems or anything like that? Should I ask them to replace the case?
