1 - 8 of 8 Posts
I just purchased a 60 x 36 drop in whirlpool tub to install in my new house. The horizontal surface on the corners of the tub have plenty of room to install a tub fill faucet. This tub will not have a shower. I would like to install a kitchen type faucet with pull-out filler neck that will switch from stream to spray. We could then use it in stream mode to fill the tub and use it in pull-out spray mode for washing hair. Anybody see anything wrong with this? Thanks
I don't know for sure but I have tried to make a couple of them flow at a higher rate and was unsuccessful. If you really have your heart set on a kitchen style faucet maybe you could find a suitable commercial kitchen faucet that would work for you or call a couple of the manufactures and see if they have any suggestions.
Discussion Starter · #8 ·
I took the faucet apart last night. Y'all are right, looks like a lot of things to restrict flow. Even if I remove the restrictor plates, the design of the diverter valve and check valves will still restrict flow too much. Guess I will either use it in the kitchen or take it back. Found a set on ebay in the color I want. It is a two handle job with roman spout and separate spray wand. The fine print says it is a trim package only, still have to buy the valve, but it doesn't say which valve. It's a Price Pfister, so guess I'll have to do some research on their website to see what valve to use.:(
1 - 8 of 8 Posts
