1 - 19 of 19 Posts
· Premium Member
soaker tub and backsplash, kitchen backsplash, Var fixes around the house.
Hi,
Have you had good or bad experiences with brands of kitchen faucets?
Delta? Moen? Kohler? Pfister?
I have been looking at single handle pull down kitchen faucets and need to pick one by Tuesday...
I like the idea of the SS Delta Deluca with the three types of jets in the nozzle. "Shieldspray" sounds good, but some warn that delta faucets break a lot. It would be nice to hear about other's good or bad experiences... Biased is OK, but please list why.
Thank you in advance.
· Naildriver
Not sure why you would need an artsy fartsy 3 spray nozzle. I have had excellent experience with Price Pfister faucets. Lifetime warranty. Brass waterway. I even had a client request a part on her 20+ year old PP kitchen faucet. They replied that they didn't carry it in stock. But sent her a new faucet to replace hers with. Good PR.
· Premium Member
My experience with Delta on warranty stuff - excellent.
My experience with PP - so so.
Where is this "Shieldspray" faucet made?
I am not sure. It is Delta... but it could be made in China.
· Premium Member
Discussion Starter · #8 ·
We just purchased new (moderate) appliances... shelled out a small fortune on granite countertops... we figure we should have a nice faucet to top it off. Not a $400 one... The ones we are looking at are nice but not ornate we were trying to keep it under $250... which is hard to do at a plumbing supply store...
Do Pfisters even use brass anymore? The house I grew up in was built in 1977. Most stuff in it still works... including the fridge, oven most sinks... I just worked on the range hood all for mom. (sure some maintenance was required. Condos an such and new stuff... are not built to last. Living on the second floor in a condo is scary stuff in NC when you face a potential water leak... which will most likely result in mold.
· Naildriver
Yes, all PP waterways are brass. I am sure you can find a great looking and functioning pull down faucet for your price range. I have several clients and a daughter who have fallen for the battery operated touch units. I am still holding them at arm's length. And there's nothing wrong with obtaining one at a box store.
I've hand good luck over the years with Moen. Have always recommended them to customers. If they leak later on, just call and they'll send you replacement parts free. Their spotless finish on their brushed nickel faucets is a very nice feature.
Mike Hawkins
I've had Delta, Moen, Price Pfister, all have been great getting parts and cartridges however the Price Pfister kitchen faucet needs a new cartridge every year, 2nd PP faucet in the past 10-15 years, and same, every year. Installed a Groehl bathroom sink faucet 2 years ago and no problem, it replaced a Mien that I had for 15 years with one? two? cartridge replacements.
· Premium Member
Discussion Starter · #13 ·
Many people do not come back and post what was done.
We wound up getting a Delta Zalia at Lowes.
https://www.lowes.com/pd/Delta-Zalia-Spotshield-Stainless-1-Handle-Deck-Mount-Pull-Down-Handle-Lever-Residential-Kitchen-Faucet/1000330083
After comparing height, reach, nozel height... and stainless finishes...
This was not even our third choice..
  • It is the type we wanted, pull down with a soap dispenser.
  • it has the Shieldspray three settings I wanted to try
  • and the "spotshield" stainless.
  • The lever is a little higher than average.
  • We both found it attractive
  • it had at least 1.8 GPM which hopefully is enough.ds
So far we are happy. The clip on the bottom seems to hold just find. The installation was included in the price of the counters... So I just watched.
I attached a pic... We are pleased. Pretty sure if it breaks, I will revisit.
Reactions: Mystriss
My experience:
Moen-good
Kohler-fairly good
PP-ok
Delta-good warranty and they need it
· Premium Member
Discussion Starter · #18 ·
I actually had delta send me the old model head... it does not have the splash guard... and I kind of like it better.
· Premium Member
Discussion Starter · #19 ·
Following up on a question I asked a while ago about the new Delta Faucet Splash Guard heads. We purchased one recently and it kind of took us off guard so I called delta and they shipped me the older kind.
1) Splash guard head - three settings.
..a Regular
..b Split spray
..c Spash guard (shown in pic with arrows.)
2) Regular head - three settings
..a Regular - lightly restricted
..b Full on spray
..c Regular - full flow (Unrestricted.)
I like both, but not at first. The splash guard is weird until you realize what it can do. The stream in the center really is high power to remove stuck on stuff the others Wont... Really! This is not apparent at first. (Not until you see it in action or put your hand in it.) The surrounding water cone does eliminate most of the splashing that would otherwise ensue. The cone is also very efficient at cleaning the sink of bits of debris like a broom. It is very good at what it does, more so than the full spray of the regular head.
The spray mode is not as pleasing on the new head. It is split apart and splashes a little more... It does not cover as much in one pass, but it is a bit more powerful and does as good of a job... It does not feel as good. (Feel?) By that I mean kind of like slicing a tomato with a sharp knife good.... or feng shui good... but you get used to it after a long while.
The water saving feature is nice on the regular head, but is of no use to me. There are other ways to conserve water.
End comment, if you are resistant to change, don't get it. It is hard to change habits developed over years and years of robotic training. (Like a new way to control your faucet after 40 years!) If you are willing to step outside your comfort zone and try something new... the new head is pretty cool... it does not come with instructions or explanations... you just have to get used to it and learn how to use its strengths... and if you do not like it, call delta and maybe they have an original head you can use. I was lucky enough to get the chance to try both... so I am passing it on as I know many of you are upgrading too.
To some people this kind of thing matters. I spend quite a bit of time in the kitchen. One can achieve a certain amount of grace and flow. (With two people it can be amazing.) Having things work properly and well... having the right tools, sharp knives... multi tasking... it is a labor but it is kind of like tai chi or dancing and pleasing until you hit a snag. No one likes it when the needle gets dragged across the record. At first the head was a snag, but now I really like it.
.No one asked for this information... but I do feel that if you ask a question and there is no defining answer... you should come back with answers or closure. Hope you enjoyed it.
1 - 19 of 19 Posts
