Hello, I've been a long time lurker and finally made the jump to posting a question.
We are remodeling our kitchen and would like to have all the counter outlets turn on and off from a switch. (We are paranoid about leaving stuff plugged in when we are not around - this would save us from having to always plug stuff in.)
We have 2 circuits that feed the outlets, everything daisy chains from 2 GFCI outlets. The feed is 12-2 for both circuits. There are 6 outlets total, with every other outlet on a different circuit.
Ideally, for convenience, we'd like to have three-way circuit control everything. So we could have a switch at each end of the kitchen. However, I'm not sure if that is possible?
Here are my options I thought of:
1) A single double-pole-single-throw light switch. (No three-way circuit possible - unless I just haven't found the right switch?)
2) A three-way switch setup for each circuit. (The +1 has mentioned she does not want switch galore.)
3) Maybe have a standard three-way circuit control 2 relays. Do they make relays that can be wired into to code? I could wire them in the basement below, it's an exposed ceiling with all the circuits labeled. I'm in favor of this option the most, if it can be done.
Anyone have any thoughts?
Thanks for any help!
Drew
Drew
