This past week, I noticed that my incandescent bulbs will dim for a second, when the AC (Heat pump) starts. The heat pump was installed last fall and I don't ever remember this happening in the past ... Not even during the winter when it was heat pumping...
The easiest way I can think of to try and remedy this is with a hard or soft start kit. I'm not sure if one is better for my problem, but I know the hard start kit is less...
With that said, which hard start kit would you recommend ... The Kickstart or 521? Or might I be better off with a soft start kit? The HP is the Rheem 3.5 ton RP14.
Thanks!
Thanks!
