1 - 2 of 2 Posts
Hey dudes. So I just had all the pipes redone under my slab. I had my plumber set my shower waste line the correct distance from the stud for the kerdi schluter linear drain. Although he glued a pipe in the trap allready. So how would I properly connect the kerdi drain?
Thanks dudes.
· Naildriver
Well, dude, you would determine the height needed on the ABS, cut it, then attach the tail piece of the linear drain to it, allowing for the proper height of your packed shower pan.
1 - 2 of 2 Posts
