model 363.9552714
part wr30x0318
i tested valve works fine i forced cycle unit and all mechanical parts work ,put water in manually and froze and emptied during forced cycle just not refilling with water ?help
Sounds like the ice maker thermostat is defective. It's what controls when the harvest initiates and when the refill occurs. It's item #16 on the link below.
Ice Maker Parts
The microswitch that gets operated by the harvest arm is also suspect so check it before doing anything else. It's item #12 in that link.
It's necessary to scroll that link all the way down to see the items individually for ordering if need be.
