I am a newbie DIY-selfer and searched for this kind of issue on this forum. The others who had a similar issue had freezer that continued to work fine. Mine seems to not, so I am posting the question.
I have a Kenmore/Sears refrigerator with a bottom freezer (fridge compartment is on top). Lately I noticed that the fridge compartment is not getting enough air or no air while the freezer seems to be getting a lot of frost buildup. I did a manual defrost (turn off the refrigerator, let it all melt over several hours, dry it up and turn back on) and the air in the fridge section seems to improve and things seems to work for a day or two. Then the same problem recurs - the air circulation to the fridge compartment decreases and then stops and the freezer had frost buildup.
The little knob at the bottom that I thought gets the defrost to kick in, does seem to be turning - I see the notch in the turning knob go full 360 degrees.
What may be the most likely root cause? I now have the refrigerator in this manually defrosted state. What should I check? Thanks in advance.
