On a recent thread, http://www.diychatroom.com/f9/conde...s-damp-roof-sheathing-next-gable-vent-353857/ ,the topic of keeping or closing the existing gable vents came up. Since I didn't want to drift on the OP's thread I've started a new one.
If you have heard the reasoning for removing those gable vents when installing a ridge vent, affectionately referred to as the short circuit theory, I'm here to explain why it is entirely wrong. Now, before you shoot the messenger, I do understand that 99% of the construction population that has read that reasoning, agrees with it. I did as well until I went looking for the actual pressures that move air through our attics and once you determine the pressures, you see why and where the air will flow.
Here's a brief description of the short circuit theory.
"When the hot air rises and exits the ridge vent it will pull in its replacement air. If the gable vents are left open they will provide a more direct path for that air flow, (the path of least resistance) thus short circuiting the desired path from the soffits."
My wording may be a bit different, but essentially this has been the explanation for decades and it has been accepted as gospel by some of the best in the industry so correcting it, which I started over 2 years ago, has been a challenge. By necessity I will try to be brief and add more information as I respond to questions.
There are three principles in their statement that we need to consider.
1. The hot air rises.
2. It pulls in its replacement air.
3. And the gable vents will provide a short circuit path because the air will follow the path of least resistance.
All three of those statements in are "wrong".
1. We often see hot air moving up, but it does not do so by itself. In our attics it is being pushed up by the cold air flowing in through those soffits.
2. The replacement air that is entering as the hot air is exiting is not being pulled in, but rather pushed in by a greater atmospheric pressure below the soffits.
3. For air to flow you need a pressure difference and a path. Despite the gable vents being closer to the ridge vent, the pressures across the gable opening and the soffit opening are completely different. The gable vent may be an intake or exhaust or a little of both, but leaving it open or closing it does not affect the pressure across the soffits, thus the air flowing in the soffits will continue regardless of where it exits, ridge or gable.
There are reasons why someone might want to close off the old gable vents, but the short circuit theory is not one of them.
More as needed,
Bud
More as needed,
Bud
