Hi;
I need to rant, so please bear with me...
I am looking at replacing the fluorescent light (double F20-T12) above the sink with an LED model. I found one on Amazon that looked pretty good, but I needed to find out whether or not the fixture needed an electrical box, or would accept the Romex or BX cable itself. Turns out that it's neither. It has only a large cutout for the wires, with no other openings. So if you want to wire it to Romex or BX, you can either not clamp the cable - just let it hang into the fixture, or install the correct box, with the cable clamped into it, and then drill two holes in the fixture to match the holes in the box to attach the fixture to the box. But from the question I posted, and the answers I received, there are no screw holes. Just the large cutout. So I guess the mfr expects you to drill your own holes, or perhaps these people aren't answering my questions correctly.
They do sell a corded model which simply plugs into a receptacle, but being that this light is intended for kitchen use, I wonder how many people know that their countertop receptacles, and any within 6ft of the sink must be GFCI protected. I can just imagine someone reaching to turn on the light (it has a switch on the fixture) while hands are on or in the sink, and the fixture isn't properly grounded, and has a ground fault...
Still, I have to expect this kind of product from Amazon. While they do sell decent stuff, I don't think they are a good source for home improvement items, and especially not electrical.
From what i have learned from others, there was a time when any product imported into or made in the U.S. was required to meet or exceed certain specs and code. Today, it seems that anyone can sell anything to anyone without regard of how it will be installed or used.
So, in the end, I am probably going to replace the fixture with another fluorescent, and I may just purchase it from an electrical supply or lighting store, and not "Home Despair" or "Amazing things from China"!
KE2KB - LICENSED HAM station. I communicate using only FCC approved equipment!
I could go on about bogus HAM gear from China as well, but I'll leave you alone now.
Edit: Here is the mounting/installation info provided on Amazon.
Easy installation:
Distance measurement: There are 2 mounting holes on the backside and 2 on the top. First, decide which 2 you would like to use; then calculate the length and install the screws. Connecting circuit:
there are 6 binding posts on the backside of the wall lamp; the left row is input binding post and the right row is output. L represents live wire and N for null line,
the medium line is ground electrode (we have circuit connection picture for reference). Install the lamp:
Just put the lamp on the installation screws gently without any additional accessories required
Binding posts? I surely hope not the type I use for experimentation...
Easy installation:
