I changed my doorbell transformer today, which was in the basement ceiling. Shut down power and uncapped the black and white wires in the junction box next to where the old transformer lives.
There were about four thick twisted wires under the black cap. I had to unwind them all to get loose the old transformer black wire. It was difficult to get the wires back under the cap but I used a linesman plier to straighten then and then retwist them as per YouTube videos. Then I wrapped the thinner black wire from the new transformer around the thick twisted wires and capped the whole thing, tight.
After everything was twisted up and the doorbell wires were screwed into the front of the transformer, I turned the power back on in the electrical box. I tested the doorbell and it worked. I tested the the lights in the den which are on the same circuit and the worked. However, the lights over the basement strairs -- which were also on the circuit and are physically *in between* the junction box and the den lights -- do not come on.
So I turned everyone off and had another look at the junction box. I undid and redid the caps. Looked around to triple check that I didn't leave any wires loose. Turned the power back on and tried the lights again, but same symptom.
Then I openned the caps and removed the new transformer black and white wires, in case this new thing was somehow affecting the lights over the stairs. Didn't help.
1. Is there anything that onvious that jumps out at you in this?
2. In general, would writes to the den lights and basement stairs lights originate separately from the junction box? Or would they be sort of daisy chained? If the former, then this seems to point to a problems with one of the black wires twisted together, yes?
