1 - 17 of 17 Posts
I am installing Ring doorbell and the doorbell wires are too short so I will need to use the provided extender. I will not be able to use the provided grey wire nuts since they will not fit in the little opening. Can I just join the wires by twisting it and then covering it with electrical tape since it is low voltage? I have limited tools and experience so I don’t want to solder or use crimpers. What other options do I have?
· Super Moderator
Imo, for a basic splice on a door bell wire (16v), using electrical tape, is fine if you have nothing else.
Better option would be to use a common crimp style b-connector which come in many choices, cheap and available at any box store. Just a suggestion.
Discussion Starter · #6 ·
You certainly can. But twisting those 20 or 22 ga wire can weaken and break them very easily. Solder or crimp is the way to go.
But I won't have to go there and fix it.....you will:vs_laugh:
Another alternative to the crimp connectors suggested by jmon would be heat shrink solder sleevesConnectors/dp/B01M1032A7[/url]
The OP doesn't want to solder.
The sleeve do not make a mechanical connection to the wires.
Soldering or crimping are the two best choices.
Wire that small has a tendency to break when twisting.
There's a difference between breaking out the soldering iron and trying to solder wires high up on a wall, and just breaking out a heat gun.
Hmm...
They both require a cord, both produce heat.
The big difference is that one is a secure mechanical connection.....the other is a friction fit.
The Telco companies use a button type crimp that can be used with a pair of pliers. It has 2 or three holes for the wire and some are gel filled for a better dielectric connection. They fit wires fro 19 to 26 ga.
1 - 17 of 17 Posts
