JFI2089AES2 I picked this up used in August last year.. tested it in the garage for 2 months before putting it in service in the basement... I did have it freeze my test water bottles so along with the drain mod and new ice maker to door seal, I changed out the fridge and freezer thermisters. Damper works fine in diagnostic mode. one thing I did notice during my testing was that my meter says the ice box temp was 6-8 degrees colder than the diagnostic says. So I ordered a hard to find ice maker wire harness to get a new thermister... But I suspect the company sent me a used harness.. I installed this harness yesterday with no change in delta from fridge display of ice compartment temp Test 145. with fridge set at 37 I was getting temps on middle shelf of 29f I did change the setpoint to 44 and now hanging near 36.
I also have messed with the Fresh food temp adjustment (211) I tried +6 but that was worse so I tried -3. One thing I read last fall about this years jenn air was that the ice compartment temp adjustment can only go from 0-+8. I think I recall that the next years Service Pointer shows they changed it to -8 to +8f. I currently have some test bags of spinach in there.
I should also add that one time during my shop testing time we had some rainy days. not all that common in dry desert Utah. not sure if it was related but I had the water flowing onto the flow issue.. This was before I replaced the new Drain tube. I guess it had the ice up on the Evap coils in the lower freezer but When I noticed this water and I looked at freezer coils there was no ice build up. I'm hoping to find someone with experience with this oldie but goodie.. or is it an old dud? i think it is a 12-13 year old unit.
