Hi,
My Jenn-Air downdraft cooktop model# CVG2420W seem to have mind of it's own for igniter spark. Sometime it won't spark at all, some time it will keep sparking even though it's already lit. Sometime issue is with only one burner and otheretime none of the burner igniter-spark work correctly.
From what I gather, I might need to replace 'spark module'. Do you agree ?
What I need help is with how do I get to 'spark module' for replacement. Is it from top ? I.e. pull knobs, unscrew side steel metal piece, remove glass top ... etc
Or do I need to disassemble the whole thing ? Have you worked on this model ? How should I approach this job ?
Thanks for your response !
