1 - 8 of 8 Posts
new windows were installed couple of days ago. the front windows are with j trim. the j trims are not installed flat on the siding. There are gaps on the side & the top portion. They install a vinyl filler at the bottom and it now looks straight.
However the side portion warps as well as the top one. according to the contractor this is perfectly normal because we have aluminum sidings. Is this true? What remedy can be done to fill the gaps? I am afraid that these gaps are invitation for insects to build nest inside. Thank you
oh...2 1/2''j channel,that will do that,doesn't really matter what type of siding you have,the face of this material is very flimsy:no:...i suppose your installer could try to ''shim'' it out some to try and straighten it somewhat but it is what it is ...sorry
1 - 8 of 8 Posts
