I will be using a pvc junction box without knockouts like this:
http://www.lowes.com/pd_145145-223-E989N-CAR_1z0xc70__?productId=3260229&pl=1
and will obviously need to cut my own holes with hole saws (small number doesn't justify buying punches).
I also wanted to add two holes for push in clamps to a Carlon 2Gang Zip box being used as a junction box only. I would easily be under max fill but need the extra clamps. I chose this box as it could take a device box blank cover as is (would look OK in the back inside face of a kitchen cabinet). A three gang has enough clamps, but is overkill fill-wize and eats more real estate than I want to give it.
Seems straightforward but I also found the following in a Carlon paper in response to someone wanting to do as I proposed:
www.carlonsales.com/techinfo/faqs/FAQ-ZipBoxes.pdf
Thanks, Jim
"Finally, if you drilled a hole in the box then you would void the listing of the product and would get tagged by the inspector."
So if this is true, where in the code is this spelled out that doesn't then conflict with cutting your own holes in a box with no knockouts or integral clamps?
Thanks, Jim
