Suspecting a dead short, I would begin by performing a thorough visual inspection of the wire from the switch to the solenoid. You may be able to determine this in short order with an ohmmeter, but not necessarily, so I would probably just remove it, and, again, perform a visual inspection. If nothing there, I would remove the ignition switch, and check it with an ohmmeter, including checking all of the terminals to the case.
