Greetings,
I installed cultured stone around a fireplace. I used regular mortar and applied directly to the backerboard without a scratch coat. Needless to say, the stone comes off the backerboard easily and cleanly leaving all the mortar still attached to the stone and a clean backerboard surface. after further reading, I see many suggestions to use thinset on th ebackerboard and mortar on the stone. Well, I am short on supplies and am wondering if I can use the stone that came off cleanly and just apply thinset or more mortar to th eback of the stone that already has dried mortar on it. I would creat a scratch coat on the backerboard with thinset before doing anything else.
What do you think ?
Thanks,
JT
Concrete & Masonry
Are you talking about removing all of the stone & thinsetting them back on?
How thick is the hard mortar on the back of the stone?
Tileguy
The stone is installed improperly and it will all remove itself in a short time. Just as well take it all down and start over.
Next time use modified thinset or a wire/metal lath and scratch-coat method using the proper mortar.:)
