Ayuh,.... Remove part of the brick patio, regrade it lower, 'n put the bricks back,....
No matter what you put over something, it's Gotta Drain,....
Ayuh,.... Remove part of the brick patio, regrade it lower, 'n put the bricks back,....As you can see, due to the brick patio, there is little room for me to work with.
They make impermeable landscape fabric for this "type" of application, but the water still has to have somewhere to go.
A window awning is probably not going to produce any significant results. A larger roof with gutters going into an actual drain system probably would, but that's a lot of work.
It's hard to say without seeing the whole property, but it may make sense to excavate and add a drain tile to move that water to a lower elevation or dry well away from the house.
I assume this has a basement? I'm not from the north.
What's the round, black - corrugated pipe looking thing, next to the house?
