Just call me Andrew
I changed the anode rod on my 10-year old Bradford White electric water heater. As you can see by the picture, I should have done this years ago...
So that's all done, it seemed to go fine. But when I turned the water back on, 2 of my sinks on the first floor (the heater is in the basement) have no water...hot or cold. Other things DO have both hot and called water in the house.
I am wondering if somehow the buildup on the anode rod (there was a LOT more than pictured) got into the tank and somehow clogged the pipes. I am not sure how it would have made its way into the cold water line though.
Any ideas? Thanks.
Just call me Andrew
Thanks guys. That was it.
Today I’ll be draining the tank so I can change the heating elements. Hopefully I’ll get whatever is left of the old anode rod.
I’ll need to replace this thing eventually I have natural gas in the house now.
Would you guys recommend an indirect fired water heater (I have a relatively new triangle tube high efficiency boiler) or an on demand unit? Or something else?
