21 - 31 of 31 Posts
Look at my post 7
Under IPC you can use combination drain and vent method on the island sink. The pipe must be 2 inch and no garbage disposals installed. Vent location doesn't matter.
I would look and make sure your plumber has pitch on the pipe 1/4" per foot. But overall I don't see an issue.
@Ghostmaker I understand what you are explaining. However, this is strictly IPC. It would not fly per UPC model code. You would need a AAV or island vent. UPC kitchen sinks are always 2" per sizing chart
I'm just trying to explain it to Chandler He lives in an IPC state.
Naildriver
somewhere on that same horizontal plane it has a vent or a vented fixture
Is there a footage limit as to where that vent must be in relation to the island?
Discussion Starter #24 (Edited)
Alright, so I tried some things and I think it's not getting enough air.
I filled up the sink and removed the dishwasher hose that's connected to the same drain pipe with a wye. I capped the dishwasher inlet with my finger, and removed the sink water stopper.
The water started to drain as normal-ish, and I slowly removed my finger from the dishwasher inlet to introduce more air. By doing that I was able to confirm the water drained the way it should, like all the other fixtures in the house.
So now my question is this....
How do I go about adding an AAV for this sink is the P-Trap is below my floor? Can an AAV valve be added before the p-trap? When I look at the plumbing, there's basically a 1-1/2 pipe that goes all the way under the floor, with the exception of the dishwasher wye in place.
This is more of a nuisance than a problem for us. It drains okay...just not as nicely as we'd like, so I'd like to get it fixed.
* Edit * Basement is finished and I'd really rather not cut anything open in the ceiling if possible.
Naildriver
We've all been working theories and what ifs, but if you could post a picture of your actual trap set up, it may help us give better information.
Naildriver
And the plot thickens...................
Discussion Starter #31
So...no easy way to correct this? Got the place like this and don't really want to cut the ceilings or anything. I can live with it if there is no easy way to add an aav to the existing setup
Thanks
21 - 31 of 31 Posts
