Hello everybody, this is my first post on the DIY forums. Sorry if it is a long one. My sister and I have been working on updating and remodeling our fathers house. The house is 768 sq ft on the main floor and is in Portland, OR. It is a single level house with a basement. It has a forced air oil burning furnace which has always worked well in the past. The original duct work is still in tact on the main floor. In the basement it was never framed properly but there were a couple rooms "divided" out with some non anchored walls. Those two rooms each had one duct in the past coming straight off the furnace.
We have properly framed in the basement at this point with insulated exterior walls. We now need to get some proper duct work into the rooms. There are existing ducts going through the rooms that we planned on tapping off of to get vents opened up in the rooms. Before I do anything though I was curious about how many sq ft the furnace should be able to heat. If it heated the space before without insulation I would assume that it would work just fine now too. If anybody out there knows a bit about HVAC I would appreciate some input. I have taken a picture of the model info from the furnace ... I hope it helps.
Thanks for any information or opinion you can provide.
