I could use some advice please. I've had my house inspected and one issue seems to be the roof. What I need to understand is whether the issue is more than just not ideal (in other words I have been told it's somewhere between don't worry about it to run for your life).
It's an older house (1930) which had some new roofing put on in 2005 (before me). I knew it was a hack job but even now, no water leaks, no problems in the attic, with the trusses or anything else that can be visually checked from inside the house. From inside, all seems fine. There are no dips or wows you can see from the outside and the roof itself seems straight and level (where I can see anyway and I was told if a roof is rotting it will start to dip in places). As an aside, I live in quite a dry climate, low humidity, not a huge snow load, average rain but much lower than in other climates. Temps can range from 80 above to 20 below here with the seasons.
It doesn't get ice dams or curl or seem to have any other issue except...they laid the asphalt shingles without removing the previous. Actually it seems there are cedar shakes covered by 2 layers of asphalt shingles so even owners before the last ones must have had hack jobs.
I assume this cuts the life of the new roof I thought I had but the question is how much? The inspector thinks the cedar may be rotting but I am not sure how he would check that without lifting the shingles off somewhere and he didn't do that and I haven't had the opportunity to ask. Maybe he walked across it and it felt spongy or something? He may have checked the edges which are visible and exposed to weather, but does that mean the body of the roof could be rotted? How do you figure that sort of thing out? Even if they are rotting, there is no evidence it is effecting the actual wood of the roof since all is fine from the inside of the attic (I assume there is tar paper between those cedar shakes and the roof) but I'm no expert.
So, if you had this type of roof what would you do? Would you wait until it was leaking or showing problems keeping out moisture before worrying about it or is it something that needs to be addressed now?
