Having a pull chain light, exhaust fan, and fluorescent light on one circuit is not a problem.
Exactly.It is a problem if they are on the furnace circuit. The furnace circuit is supposed to be dedicated.
I would stop using a handyman for electrical work.
Yea I was thinking about that too.. but he said since it is a gas furnace the only power draw is the blower and theoretically shouldn't be able to use that much power to cause a problem...It is a problem if they are on the furnace circuit. The furnace circuit is supposed to be dedicated.
Sounds like your town have more regulations than it needs, you must be near Chicago! Is it still possible for a homeowner to do their own work such as replacing an outlet or does everything have to be done by an electrician?In my last house, electricians were required to be licensed within the town in addition to the state. Any work, even a single outlet, done by a licensed electrician must be inspected by their underwriter.
And that seems to happen quite often??So now if the pull chain light, florescent light, or attic exhuast fan short out, you have no heat.
Depending on crash circumstances, it could make injuries worse.I am hoping my airbag will protect me in a crash, but I hope I don't have to find out
Nobody but you said any of that. People overwhelmingly recommended using an electrician, some because of code or insurance reasons and some because electricians are much more *likely* to do electrical work correctly. It's their job and they've done it for many thousands of hours. A lot of handymen can do simple electrical correctly too, although usually it's illegal for them to do so professionally and/or insurance won't cover their errors. Even more can do electrical that works but isn't correct.Just because a guy holds an electrical license doesn't mean he will follow the code.
It's easy to sit on the interenet and talk about how ALL electricians are doing the job to code, and ALL the handymen are not.
No doubt that since he's only a handyman, he doesn't know how to use wire strippers, wire nuts, etc, etc. After all, he's just some dumb ass handyman.
