There is a closet under the stairs in my basement and I want to move the door to the adjacent wall pictured. (note, the current door opening is in a wall that looks identical to the one in question and it does not have a header). The wall In question is parallel with the joists but one of the studs is close to the end of stairs, which concerns me. Also, the joists are parallel but the top of the wall in question seems to have its own joist (it isn’t just an open cavity above the wall, there is a large hoist type of wood plank that goes all the way up) - Is this wall load bearing? Even if it is not load bearing, should I put in a header just in case (due to the proximity to the stairs)? Also, the door I want is a 30x78” glass door, so it is quite heavy and may need a header?... furthermore, an election will be removing the outlet (silver pipe looking thing) and the telephone line (wire just dangling all scary)
