1 - 12 of 12 Posts
I got the spacing thing figured out pretty good, but what about the distance a baluster should be from the stair tread/nose? should it be the same as the distance from the newel post to the first baluster?
thanks
Laurie
For open risers, place the down side of a baluster so that is flush with the face of the riser. Every tread will have a baluster in this spot. Divide the run into equal parts and that is the spacing for the others.
You are looking for uniformity and consistency of the balusters and the treads.
· Old School
This may simplify it if your treads are 10" from nose to nose as many are. If not, using 10" like this shows you some easy division to apply to your own measurements.
(All these measurements are "center-to-center" of the balusters... so your baluster size doesn't effect this layout.)
And "No", they don't necessarily have to be right on the edge like I've shown it. Some are, many aren't.
· Registered User
· Old School
The setup on the right is the maximum you can go with this layout, using 1.5" wide balusters. It just does leave you 4" between... and if your baulsters are smaller than 1.5", or narrow down anywhere, this layout won't work...... you'll have to put three balusters per tread, spaced much closer together.
Stay aware of things like this.
· Old School
4" or less distance between balusters is required by code. An inspector was always checking our distances, when I worked as a superintendent.
That's why I said what I said. Both these drawings show that. The measurements you see are "center-to-center".... meeting code if using full 1.5" balusters.
· Love for Construction
Never said you didn't say that. And I fully understood the drawings.
*EDIT* I just realized I probably hit the quote button rather then reply. If so, sorry my fault.
· Old School
No, my fault, I should have said: "It just does leave you the code required 4" between...".
1 - 12 of 12 Posts
