1 - 17 of 17 Posts
A "Handy Husband"
Looking for a converter to convert a 220v Dryer outlet to be used as 110v without rewiring. Anyone know if this can be done?
If you live in Canada and have a 4 wire dryer receptacle, Home Depot (Canada) sells a device that will do what you want. If you are in the USA, it is not compliant.
Most dryer receptacles in the U.S. provide both 120 (110) volts and 240 (220) volts because the dryer uses both.
You can make a power strip (portable subpanel) with a cord that plugs into a 120/240 volt dryer receptacle and that has some 120 volt receptacles protected by 15 amp or 20 amp breakers. This cannot be used on a 240 volt only dryer circuit; you may not use ground as a neutral for 120 volts.
You may not have 15 amp or 20 amp rated receptacles connected directly to a circuit that can supply more than 20 amps.
Licensed Electrician
No you can't. A sub panel would need to be hardwired.
A "Handy Husband"
RJ, do you know if that device has a breaker on it ? Or, are you plugging a 15 amp appliance straight into a 30 amp circuit ?
I believe it has an inline (internal) fuse to limit it to 15 amps. I was just looking at the HD Canada web site but could not find the unit but I have seen it in the past.
Reactions: Oso954
A "Handy Husband"
Here is that adapter to convert a 4 wire receptacle to a 120 volt 15 amp receptacle.
Noticed it a range recep, converter not a dryer
Sold at Home Depot Canada. Not UL listed.
http://www.homedepot.ca/product/gas-range-adaptor/905477
Has internal 15 amp fuse.
Not sure why it would not meet code in US but it would be a useful device.
$33 isn't cheap, but I expect an electrician would be several times that; nice device.
I have seen a device that does just the opposite. You plug it into two outlets on opposite legs and it makes 240v. I hope that is illegal everywhere.
Is it possible - YES ! but only if it is a 4 pin recepticule !
But it may not be code compliant !
You should not use ground as neutral.
Its basically risky if not done right.
which is why its NOT code compliant.
Master Electrician
It's a converter listed for gas range applications. I've never seen one before but generally we can only use devices for their intended purpose so plugging anything other than a gas range into it may be illegal as it states its for gas ranges only.
Super Moderator
The receptacle for a dryer is different than a receptacle for a range. Unless you can find an adapter from dryer to 120 that one pictured will not work.
That adapter is only available in Canada. I have been able to find it listed on any USA sites.
The other fact is that Range plugs and Dryer plugs are not the same pin out, due to the different current ratings.
It would not matter what kind of (male) pin out arrangement was used where the adapter was internally fused for 15 amps, or could be 20 amps when equipped with a duplex (female) receptacle set fed by one of the hot lines.
Actually there is a disadvantage using this adapter behind a stove, e.g. when converting an electric stove to gas. If the internal fuse blew (or an internal breaker tripped) it would be necessary to move the stove to reset the adapter.
Super Moderator
Tripping the fuse in that device would not be a concern to me for even a second. I don't know about anyone else but I can not remember the last time tripped a breaker on overload much less a dedicated line to a stove that only draws minimal current for the electronics.
1 - 17 of 17 Posts
