1 - 10 of 10 Posts
Living out here in Southern California, bricks are just not permitted due to the earthquakes. Stucco is the main exterior material of choice --and I can understand why: It's basically a cement coating of your house. But I was just wondering if you guys are aware of materials that would actually out-perform conventional stucco for an exterior covering... Or is stucco king?
· Remodeling Contractor
what look are you interested in? In NE I have done siding with 6-12" granite stones. Much stronger than stucco. You can consider cement siding which comes in shakes or planks. This will not crack as much as stucco does and colors last better.
· Registered User
Check out a product called Carerra (sp?). It is a one-coat stucco that is sold in buckets, and the stuff is incredible. It can be applied over LP smart system siding and trim boards and gets a 50 year warranty. I tried a 3 pound mallet on some samples and was able to slightly dimple it but couldn't crack it. It is flexible and durable. I took the same samples to the gun range (at the request of a rep) and put holes through it with a .223 carbine and a .45 auto pistol...Clean holes, no cracking or flaking. I hate stucco and I am completely sold on the stuff. I know it is gaining popularity here and in the south, and they might have distribution in your neck of the woods. Worth a look.
I'm not. I've got a house that's half stucco and half exterior wallboard that's rotting away (even in the desert!). I'm going to be doing some room additions and just want to explore exterior coating options. I'm a fan of ANYTHING that will last a super long time and withstand the desert climate.
I have a kevlar house. From what I've heard, it should last a very long time. You might want to look into that possibility.
You need to be careful about the supplier, as I've heard they can be unreliable.
You know, low bidder...
Ron
here is a product you might want to look into.Its called Conpro Flex by Conproco Inc. You put on your brown and finish coat of skin coat then you can trowel ,paint it on or even roll it on depending on the finish you want.Its acrylic synthetic so it last longer and comes in over 57 colors.I am useing it on my home here in Pa.and was told it will hold up very well to the harsh winters so far its doing well and goes on easy.Its is very DIY freindly.I am not sure if this is the same as the other produts mentioned
1 - 10 of 10 Posts
