so i'm trying to wire up a new electrical outlet for a tv. busted up the walls and drilled holes through the studs. then i knocked out a corner of the jbox. i wired the new romex to sides. the white to the silver screw, the black to the brass screw, and the ground attached by a cap. i believe the romex is fine going through the insulation right? i'm getting 120v. anyone see anything i should be aware of?
the outlet i wired up to
https://www.box.com/s/8eiy05j7c4uugvl6qp9l
wiring through the studs and insulation
https://www.box.com/s/vlxtndrbj0ylxn17j8me
