1 - 7 of 7 Posts
i have a frost hydrant in my shed, from there there is 3/4" PVC pipe to an outside spigot to which a hose is attached. even though the hydrant was turned off and i do have a leakout system for leftover water in the pipe, some water drained back from the hose and into the pipe and froze there. the spigot valve is blocked frozen.
i wonder if it is safe to take heat gun to the PVC pipe as i really need to use the hose (and don't care if it freezes again after i do). my concern is that i might deform the pipe or melt the fittings.
thanks
I would be skeered to try a heat gun, they get hot, maybe a hair dryer, or as others suggested, stick a heater in the shed for a couple hours.
Not sure if this is important, I was told by our plumber, that if you leave a hose connected to a frost free hose bib, they will freeze, they can not work as they are designed to.
In this case, actually burst in the wall and caused some drywall damage.
I imagine your hydrant works with the same principle, when you get it thawed and done with the hose, disconnect it and may not have the problem again.
1 - 7 of 7 Posts
